Horn replacemen on a 2018 ford f150
Old Sep 16, 2020 | 11:35 AM
jballance's Avatar
Default Horn replacemen on a 2018 ford f150
One of my horns is not working and I need to know how to access them so I can replace them. Does anyone know how to access the horns without removing the frn grill?
Old Sep 16, 2020 | 12:52 PM
scott.butler4's Avatar
Horn is on pass side, take the electrical connector off then unbolt the 2 horns from the bracket and slip them out the side.
The nuts for the horns are 10mm, note which horn has the connector for when you installed the new horns back onto the old bracket on the vehicle. Don't throw out the nuts until you have the new horns installed.
I slip my arm in from the side of the grill,
you won't be able to do this method if you have bulky arms, the gym crazy guy at my dealer has to take the grill off to replace them cause his arm doesnt fit.
Old Sep 16, 2020 | 12:54 PM
jballance's Avatar
thanks
Old Sep 16, 2020 | 01:03 PM
jballance's Avatar
I just went and looked again and I dont see where you can access fro the side do you have a picture Do you have to remove anythng to access?
Old Sep 16, 2020 | 01:04 PM
You may need remove the radiator air damn aka the thin flexible black plastic sheet.
Old Sep 16, 2020 | 01:08 PM
jballance's Avatar
The one on top?
Old Sep 16, 2020 | 01:59 PM
You might have to remove the top part as well.
If in doubt just start removing parts and see if that gives you enough room, thats what we do for jobs where there isnt any directions.
Old Sep 19, 2020 | 11:44 AM
Use Common Sense's Avatar
If you're still in the 3 yr/36,000 warranty period I would make Ford replace the horn(s).
oldad
Mar 9, 2018 12:06 PM
Stephen Mauersberg
Dec 20, 2013 05:41 AM
Boxer19
Aug 29, 2012 11:28 AM
jbelgodere
Aug 19, 2008 08:03 PM
doublef2006
Sep 25, 2006 06:17 AM
