idle air control
Old Oct 15, 2007 | 08:43 PM
greuelc's Avatar
Default idle air control
my 1991 ford f-150 5.8l has been idleing funny and it does not always kick down after driving it on cold days. My main guess that it is the idle air control valve. Or is it some thing else that could cause this. How should i fix it.
Old Oct 18, 2007 | 06:20 AM
spiderdood's Avatar
Default RE: idle air control
While its idling to high unplug the iac, if the idle stays high its probably the iac. If it comes down then its being commanded high by the pcm. Your tp sensor could be going bad. Tp mode should read CT(closed throttle) at idle. If it reads PT(part throttle) even with the throttle closed then iac percent will be commanded up and cause the idle to be too high.
Old Nov 4, 2007 | 07:50 PM
greuelc's Avatar
thanks for the reply i did what you said and the idle went down. Where is the tp sensor. Keep in mind that it does not do it every day.
braydee0521
Feb 15, 2007 01:19 PM
TimH
Dec 8, 2006 06:37 PM
apollo
Oct 5, 2006 11:32 AM
geano420
Jan 17, 2006 11:18 PM
geano420
Jan 17, 2006 10:11 AM
