LTB something for better MPG...
Old Oct 26, 2006 | 12:56 PM
live4perfection's Avatar
Default LTB something for better MPG...
considering purchasing an intake for my '03 F-150 Lariat 4x4 w/ 6" lift and 35" tires. ive been getting 10-12 MPG and have heard that an intake would help my MPG...but how much? dont care to much about anyhting else but gas mileage, pretty satisfied w/ everything else. ive also heard something about a "CHIP" as another alternative...where can i get these things? PLEASE ADVISE, on what brand (model # would also help). thanks for ur info.
Old Oct 26, 2006 | 01:52 PM
Bullitt94's Avatar
Default RE: LTB something for better MPG...
Superchips would be a good place to start. Oterwise use a search engine to look for automotive performance chips.
Intake and exhaust could help. K&N airfilter would help. The difference in mpg isn't going to be staggering by any means.
Old Oct 26, 2006 | 10:49 PM
masterexploder's Avatar
those things will help, however with the money you spend on them it will take years to save the money on gas that you spent on the intake, or chip
Old Oct 27, 2006 | 09:47 AM
Bullitt94's Avatar
Very true. You could spend up to around $2000 buying a chip, intake, and full exhaust system. $2000 can buy a lot of gas!
Old Oct 27, 2006 | 11:33 AM
i will proly buy an air intake for around $200...would that be worth it? which brand is best/better in terms of gas mileage?
Old Oct 27, 2006 | 01:52 PM
Bullitt94's Avatar
Another thing with air intakes to watch out for is if it is an intake that will be sucking air from the inside of the engine compartment or from outside the vehicle. The air inside the engine compartment is warm/hot compared to that of air from the outside.
Sucking in warm air can have no effect or even a negative effect on engine performance. Cool air is denser, so you have more molecules in the same set volume as warm air. The more air molecules you have per set volume, the more "air" the engine can use to burn. The more/better the engine can burn fuel, the more power it can produce. This is one reason that intercoolers are now used in turbos and superchargers.
You could get a K&N air filter for about $50 that would help out.
Old Oct 27, 2006 | 11:12 PM
yeah, you could just buy the filter another thing is those high flow air filters don't really filter the air as well as OEM filters, i have seen a lot of trucks get their motors dusted from running those filters in the desert
Old Oct 28, 2006 | 12:11 PM
whitecrystal1's Avatar
what size gears are you running?
Old Oct 29, 2006 | 10:35 PM
to be honest...i have no idea what gears i am running. i just bought the truck as is. would proly need to find out...but what difference would that make...would it be that obvious if some adjustments werent made cause of the lift?
Dustin1981
Jun 1, 2020 10:56 AM
1 more Ford
Jun 16, 2014 03:15 AM
92F250
Jan 28, 2008 09:23 AM
denjal
Mar 10, 2007 01:58 AM
HotRodderx
Dec 16, 2004 12:51 PM
