My F150 lariat
Old Aug 30, 2022 | 03:54 PM
Tammywaugh77's Avatar
Default My F150 lariat
Hello all I'm new to this forum and was wondering if someone could possibly help me with ideas about my truck
I have a 2008 F 150 lariat with the 5.4 3 valve motor.....having issues atm with the transmission malfunction light and the code reader said its the shift solenoid A .....we replaced the check ***** in the valve body of the trans and changed the shift solenoid put it all back together took down the road and the same code is still popping up. Any ideas on if the computer needs to be reset or what else could be done...... i just want to be able to get back into my truck and drive it with no issues .......
Old Aug 31, 2022 | 06:53 AM
What as the code you keep getting?
Old Aug 31, 2022 | 06:46 PM
P0750 is the code I get which is the code for shift solenoid A which we replaced.....
Old Aug 31, 2022 | 07:34 PM
The code doesn't specifically say replacing the solenoid will correct the problem.
What it does tell us is,,,,, the reading the PCM is getting is not within specification and that could mean anything that controls solenoid "A".
Now it is time to check all the connections and maybe it is something you can see . Electrical connections can be difficult to tell just by looking at them, they need to be verified with a good meter.
Also if for example the MLPS ,(Manual Lever Position Sw) was called neutral safety sw, is not functioning correctly , it could cause that code to come up. There a few other things to check and they are listed in the list of possible causes on up to a trans control module. The path the info takes needs to be checked and verified receiving the correct info as well as sending that correct info. So right now it might be a good start to check all wiring going to the trans where that signal eventually gets to sol A.
Old Aug 31, 2022 | 10:06 PM
Thank you..... we will start there and I'll update after we go and check it out....
Old Sep 1, 2022 | 10:20 AM
I should have mentioned this earlier.
When checking wires and plugs, keep a sharp eye out for any corrosion inside any plugs where most folks don't look
Old Sep 26, 2022 | 12:33 PM
Default We found her issue.....
We went through truck and changed out a few sensors and finally found the right sensor .... come to find out it was the crank sensor...Finally she is back up and driving with no issues
Jdwardus
Mar 26, 2021 06:11 PM
rudy33
Mar 23, 2016 12:26 PM
Artisan
Jan 3, 2012 11:49 AM
rlucero316
Sep 17, 2008 05:52 PM
treetopp87
Aug 17, 2006 07:44 PM
