need a question answered.
Old Apr 26, 2016 | 07:17 PM
tubatim45's Avatar
Default need a question answered.
So I am new to my 1985 f150 300 cid. I love that I6. Now the problem I have is I have replaced the alternator and the battery dies fast, I looked at a schematic and it is attached correctly. Someone off hand mentioned a generator. Now I know the difference, but does this specific engine take a generator instead. I really want to get that truck back on the road, because my little v6 sonata isn't cutting it.
Old May 22, 2016 | 02:14 AM
Fordbraat's Avatar
It sounds like it is your voltage regulate. My 1980 F 250 had a charging problem after I replaced the alternator and I replaced the voltage regulator and it fixed it right up.
Old May 22, 2016 | 10:20 PM
primem's Avatar
generators have not be used in 40 years. your vehicle uses an alternator.
you need to perform some tests before replacing any parts. the first test is to have the battery tested. If the battery passes a conductance test; start the vehicle, turn on every electrical accessory the vehicle has and measure the voltage across the battery. You should have between 13.5 to 15 volts.
Old May 23, 2016 | 01:42 PM
Alanah_Rae's Avatar
welcome mate on a board !!
Christian0001
Sep 11, 2012 07:13 PM
dj_mindframe_99
Jul 12, 2009 03:35 PM
dmb5675
Jan 21, 2009 07:41 AM
whitecrystal1
12
Aug 18, 2006 12:22 AM
mike2076
Jan 18, 2006 09:57 PM
