new break switch and still cant shift out of park.
Old Feb 8, 2013 | 07:23 PM
jimbokicksass's Avatar
Exclamation new break switch and still cant shift out of park.
I was recently in the desert and i high centered on some sand. since than i cannot get into gear while the truck is running and i have no break lights. i just changed the break switch and all fuses are fine. all wiring is good that i can see. so i don't know whats wrong. before the trip i was messing around with the tow lights because they were acting up, any ideas?
Old Feb 8, 2013 | 07:54 PM
Thumbs up
Welcome to the site..
What year is your 150?
Old Feb 8, 2013 | 10:18 PM
sorry its a 98 4x4 lariat
Old Feb 9, 2013 | 01:39 AM
After the swap on the brake pedal switch, did or have you tested there with a light/meter for 12v on the LG/R wire at the switch connector?
If you have no high mount stop either, could be the trailer adapter was damaged on the sand. If it shorted, if could pop the fuse for the shift lock..
Old Feb 16, 2013 | 08:59 PM
i havent tested for power but i did check all the fuses and there all fine. even the ones in the hood. the tow light connection is all cut up from someone splicing the wires right into the trailer wires but it hasnt affected me till now. i do have a aftermarket trailer breaking system but dont know if that has anything to do with it.
kerley
Sep 4, 2013 12:40 PM
Elayne
Aug 21, 2011 12:57 AM
homedepot
May 31, 2009 11:18 AM
rlevy64614
Sep 25, 2008 09:13 PM
