new mwmber, old carb '78 f-150
Old Oct 8, 2008 | 11:13 PM
hix007's Avatar
Default new mwmber, old carb '78 f-150
Hi everyone,
I recently puchased a '78 f-150 with a 300 c.i., manual on the tree. It runs sound, however, I've been to the junkyard to do some upgrades. Since I know absolutely nothing about how trucks operate, I would appreciate any answer to my beginner questions. First, let me say that I believe you can do anything that you put your mind to and I have since purchased some basic tools and literature to get me started on this endeavor. My plan is to put back itto stock with a few custom options. Second, these questions really will be somewhat simple and as I am a somewhat simple man, I pray you can bear patience with me.
OK, here we go.
1. I have two single barrel carter carbs and I'm trying to find the model number for each. Neither has a tag, however I do believe they are YFA models. On the bottom of the throttle bodies are stamped 7174S (on truck as purchased) and 7460B (remanufactured and puchased from the junkyard). Are these the correct model numbers or am I missing something? Research online at the carburetor doctor has identified that these model numbers would fit my truck and the truck from the junkyard.
2. What is the wire on the back of the choke thermostat used for and where does it plug-in? The junkyard carb came with many different lines that I disconnected (I believe the truck was an '83 f-150), but my truck did not have the same vacuum ports,vents or tubes so I did not need these lines. Both carbs have the wire leading from the back of the choke termostat.
3. Does anyone have a schematic for thes carbs online? I have a Chilton's guide to feedback carbs I got from the library but it is somewhat confusing because the pictures don't quite match exactly tothe carbI can hold in my hand. Also, I ould love to find a hard copy of the ford truck shop manual. They've got dvd's, but I'd like to add to my collection of material.
That's a start. I'll be back for more. Thanks for the help.
"Keep on truckin'".
Old Oct 12, 2008 | 05:57 PM
oldtimer35's Avatar
Default RE: new mwmber, old carb '78 f-150
Well, a YFA is a YFA. Had one of the 78 six bangers for years, very good truck, couldn't beat it to death. I put 250,000 miles on it and gave it away. The wire your talking about is the electric choke and I think it plugged into the same wire for the carbon canister vent solenoid.
Old Oct 13, 2008 | 12:23 PM
hix007's Avatar
Thanks "Oldtimer", I've been asking my future father in-law about that wire and he wasn't quite sure about it. I need to get my hands on a wiring schematic. I'd like a hard copy. Any ideas where to get one?
Old Oct 13, 2008 | 02:50 PM
Bullitt94's Avatar
There are wiring schematics in the back of Haynes and Chilton Manuals. They run about $16-20, and offer instructions on how repair most things on the vehicle.
Gene13820
Nov 6, 2011 12:49 PM
cdale_sam
May 16, 2009 06:23 PM
hix007
Oct 8, 2008 11:00 PM
tonelaz22
Sep 22, 2007 03:45 PM
truefordman73
Oct 26, 2005 01:22 PM
