No Crank No Start, and replaced a lot of stuff!
Old Nov 26, 2013 | 11:06 AM
Visvire's Avatar
Default No Crank No Start, and replaced a lot of stuff!
Gentlemen, I would ask for any advice you might have. I am in a very somber mood, having just replaced the starter, starter solenoid, battery, spark plugs, and rotator cup/cap on my 86 Ford F150.
Sure she is an old vehicle, but used to run great. I made an effort to start her at least once every few weeks but I slipped up and a month past before my latest attempt. Prior to replacing the parts mentioned, I attempting to jump with no luck, and even crossing the nuts on the fender relay switch. With the new parts, I get the same result.
I wouldn't necessarily describe it as a "clicking" so much, but more like a loud buzzer, emanating from the starter solenoid. My only suspicion now ,which I have little experience with, are a inline fuse, clutch safey switch (if exists?), or bad ground somewhere. Are there any commonly known issues that would cause this? What would be your next step?
THank you in advance
Old Nov 26, 2013 | 04:30 PM
If you can, open the cable insulation with a small slit in the area of where the battery cables connect to the battery. If you see any corrosion the cables could be the problem.
aaron_mustang
Dec 19, 2011 09:47 AM
rxbahamut
Feb 12, 2011 03:57 PM
mmarashe
Apr 25, 2009 01:03 PM
trains11tjc
May 31, 2005 04:16 PM
