overheating probs
Old Nov 9, 2004 | 11:39 AM
Cwzanth's Avatar
Default overheating probs
Hey all I got a 1985 f-150 with a 302 carbed in it.
I just replaced the valve covers and replaced the header gaskets. I started it the other night and my headers were GLOWING red, luckily I turned it off in time before it hurt anything. I have no idea what is wrong, oil is full and brand new as is the radiator fluid.
If anyone can help me with this matter I would greatly aprreciate it.
Old Nov 10, 2004 | 03:41 AM
grampztoyz351's Avatar
Default RE: overheating probs
First thing I'd do is check the timing, has it backfired or dieseled ( tried to run backwards) when you shut it off, if so it may have jumped time then you'll most likely need to change the timing chain and gears.
Old Nov 25, 2004 | 06:10 AM
94Flare's Avatar
If your running headers dont get too concerned..the exhaust coming out of the heads is well over 600F degrees and metal especially the thin material that headers are made from (14 Gauge and thinner) will glow at that temperature. I have seen cast iron manifolds glow at night also.
askedofgod
Jul 18, 2015 11:53 AM
kenny 40ltr
Sep 17, 2005 12:00 PM
alexma21
Sep 10, 2005 03:02 AM
sethro
Jul 21, 2005 10:25 PM
kiltwearinfool
May 8, 2005 02:54 PM
