pullys and belts whats the best brand
Old Dec 27, 2006 | 10:14 PM
Andrew beiler's Avatar
Default pullys and belts whats the best brand
i'm having to change the idealer pully on my 97 f-150 and don't know if i should go to ford or somewhere else. should i replace the tensioner also i'm going to put a new belt on it also. just want to know whats going to last and find out from someone thats tried it and knows what to do in this position. has a 4.6 v8. please help need to know asap so i can put it on before the weekend. going 500 mile up the road.
Old Dec 28, 2006 | 11:43 PM
BigChevy80's Avatar
Default RE: pullys and belts whats the best brand
In my opinion, dealers should be avoided unless you like paying a 400% markup. I usually buy all my parts at NAPA, and since I have AAA I get a 7% discount on most parts. I've never had any problems with the pulleys I've got from them. Usually their parts are of better quality than AutoZone, Advance Auto, O'reilly, etc. I wont even walk into an AutoZone anymore.
You might as well replace both the tensioner and pulley at the same time while you have the belt off.
Old Dec 29, 2006 | 11:28 AM
thanks, i used to work for napa up until i came to ohio for college. i have always done just what you said but the dealer was cheaper on the pulley andtensioner where 30 dollars less than napa or advance???????? so i really quized by this. anyway do you need a speacail tool to get to the tensioner to lossen the belt?
Old Dec 30, 2006 | 01:06 AM
BigChevy80's Avatar
Well thats odd, but if it's cheaper then I guess you can't get much better quality than OEM (I would hope).
I believe that the tensioner should have a square hole that you can use a 3/4" ratchet handle or breaker bar to release the tension.
Old Jan 3, 2007 | 02:28 PM
thank you for every thing. it went great and i went home and came back and did wonderful.
SyPHER
Apr 10, 2007 03:24 AM
gags61
Apr 9, 2006 01:59 AM
gags61
Apr 4, 2006 10:17 PM
c2321
Aug 20, 2005 07:38 PM
tyroner
Jul 6, 2005 12:33 PM
