radio
Old Oct 6, 2005 | 11:15 PM
fordman87's Avatar
Default radio
any one install a cd player on a 87 F-150
i tried installing one and my stock radio kina workes but not fully and when i put the cd player in thier it wont work it wont even turn on. i got a wiring harness for it but it still wont work I was wondering if u could give me some tip on what to do!
Old Oct 9, 2005 | 10:28 PM
rusty ol ranger's Avatar
Default RE: radio
I was wireing a newer radio up in my 79 and after lots of pain staking troubleshooting, never finding out why it wouldnt work, I found out my antenna wire was bad.
Replace that and see if it fixes it. Everything grounds through that.
later,
Dustin
Old Feb 14, 2006 | 06:13 PM
05ranger's Avatar
Default RE: radio
You may need to try to run a new hot wire. In a lot of cases this will fix the problem. Also run a wire from the wire that is hot only when the key is on. Use a test light and find a fuse that is only hot when the key is on. You can then run the wire under it. Hopefully you can get it worked out. It is not impossible. I have put 2 in a 1986, 1 in a 1967, and 1 in a 1987 4X4. Good luck.
kneivel
Feb 15, 2023 05:30 PM
b3n129
Sep 20, 2008 05:59 AM
roundman
Jan 25, 2006 05:25 AM
steven
Feb 28, 2005 07:16 PM
