Rebuild engine?
Old Nov 22, 2008 | 12:53 PM
gblvdgirl's Avatar
Default Rebuild engine?
I have a 97 F-150. We went to change the plugs to find out there was oil on one. We didn't check the others. Someone said the engine needs to be rebuilt b/c the seals are leaking. Is this true? How much does it cost? How long can I drive it like this before it gives out. We pull a utility trailer with it.
Old Nov 22, 2008 | 12:59 PM
way2old's Avatar
Default RE: Rebuild engine?
How much oil? You need to do a compression test to determine if it needs rebiult. These engines are known for leaking around the valve stem seals. If it is leaking valve seals, you can repair it without a rebuild. You can repair it in the vehicle and is not terribly expensive or tiome consuming.
Old Nov 22, 2008 | 01:05 PM
gblvdgirl's Avatar
The entire spark plug was saturated with oil. It was 2 quarts short. We filled it and then pulled the plug. It was fresh oil on it. Balpark on price?
Andydontknow
Sep 26, 2011 08:37 AM
Piperman
Nov 3, 2009 10:06 PM
ford79
Oct 3, 2009 12:00 AM
ford79
Sep 24, 2009 11:06 AM
natesmustang
Oct 20, 2006 11:33 AM
