replaced instrument cluster
Old Aug 19, 2017 | 02:16 PM
electrician90's Avatar
Default replaced instrument cluster
I replaced my instrument cluster with a used one and now my truck won't start. Do I need to reset the PCM?
Old Aug 19, 2017 | 02:22 PM
After a certain year , the instrument cluster is one of the modules in a network and could require the reprogramming.
Old Aug 19, 2017 | 02:23 PM
I had a 1999 f150
Old Aug 19, 2017 | 05:59 PM
If you have not solved the problem yet, you might try removing the negative battery cable from the negative post and holding the the end you removed against the positive cable a few minutes to allow the computer to reset. Try it and see if it helps.
Kurt1s
Nov 4, 2013 03:40 PM
mrcol
Jul 9, 2007 08:58 PM
sisdavid@yahoo.com
Aug 9, 2006 11:32 AM
gpressick
Jul 14, 2005 06:05 PM
jtt3769
Jun 4, 2005 12:12 AM
