Rough idle/arcing at plug
Old Oct 23, 2009 | 04:30 PM
  #11
91F150XL's Avatar
Yeah, i've seen it at more than one of the plugs, atleast 3 of them are doing it. I've done all that I can think of to try and stop it but nothing has worked.
Old Oct 26, 2009 | 09:06 AM
  #12
Bullitt94's Avatar
If it is arching at the plug(s), then the boot(s) for the wire(s) are either not on all the way or they are bad. I think you said you replaced them, but if you pulled them off a few times, you may have cracked the boot slightly without knowing it. If they weren't on all the way for a while at first and were then put on all the way, then they probably burned up and are shot. Regardless of what happened, that is the problem is. Try a new set of wires; it's worth the $20 to rule it out or fix the issue.
mardyel
Sep 23, 2025 05:41 PM
MGood777
Oct 27, 2023 01:34 PM
NYRPM
Mar 5, 2018 12:33 AM
troyhay
Nov 4, 2010 04:47 AM
Olpapa
May 18, 2008 03:22 PM
