schematic for 2014 f150 eco boost
Old Sep 1, 2017 | 06:10 AM
Hobbes's Avatar
Default schematic for 2014 f150 eco boost
I'm hardwiring a dash cam into my truck and want to find the right wire color to tap into for accessory power only. This is my first time on any forum. Hope I'm posting correctly
Old Sep 3, 2017 | 10:55 AM
Hobbes's Avatar
I know I'm replying to my own message here but upon further investigating I found this. Hope it helps all who needs it
https://www.fleet.ford.com/truckbbas...bodybuild.html
Old Sep 3, 2017 | 11:11 AM
Welcome to the site
Missed your post,, if you need any specific circuit help for tie in let me know..
Old Sep 3, 2017 | 10:49 PM
Hobbes's Avatar
I have ran the power wire down the passenger side column and am curious as to what color wire is for what circuit on that side of the vehicle. I just don't want to go tapping into the wrong circuit since newer vehicles are so electrically sensitive. the link I put in my own reply should help, but the only problem is it doesn't indicate passenger or driver side of the vehicle. It looks more like a ladder diagram than a schematic
Old Sep 3, 2017 | 11:25 PM
You want the camera to power Off with ignition, correct?
Old Sep 5, 2017 | 08:38 PM
Hobbes's Avatar
yes. turn on when I start the truck and turn off when I shut the truck off
Old Sep 5, 2017 | 11:55 PM
If you've already run wire on the right/passenger side,, if you 'don't' have SONY sound, there's a customer access connector in the right kick panel that's 'Hot at all times' and circuit protected to 20amp. Without Sony sound,, the circuit is empty. Customers access to supply camera load current, and Ignition switch relay control for ON/OFF switching.. I can send you the connector image and location..
Keeping the cameras combined load from Module/circuit protection limits or potential overload, you could use a micro SSR relay and use the White/Orange wire (Run) off the Ignition Switch connector/harness to trigger the relay. Micro SSR would be a very small draw on the circuit..
What's the camera load/amp draw?
Gamefish27
Aug 28, 2017 08:44 PM
Jlaborde1985
Aug 21, 2017 05:41 AM
BVRS
Aug 9, 2016 03:32 PM
csearing
Nov 2, 2013 10:53 PM
Cappy
Jun 28, 2011 12:00 PM
