Seat belt light and noise
Old Nov 14, 2007 | 07:27 PM
hillbillydeluxe's Avatar
Default Seat belt light and noise
Does any one know the code sequence or what needs to be done to get the seat belt to stop alarming all the time ? Its on a 2003 F150
Old Nov 14, 2007 | 09:14 PM
techmanbd's Avatar
Default RE: Seat belt light and noise
Are you talking when you don't use it? I remember in the work trucks I use to use at one company had F150's and all we did is when we got into the truck started it, and it was dinging, was push in the release button of the belt latch.
Old Nov 14, 2007 | 10:34 PM
Yes thats correct when the truck is being used and the seat belt is not.
Old Nov 14, 2007 | 10:58 PM
Belt Minder Deactivating/Activating
[/align]Preparation
[ol][*]Before deactivating/activating the belt minder, set the parking brake.[/ol]
2. Place gearshift in P (Park) (automatic transmission) or the neutral position (manual transmission).
[ol][/ol]
3. Place the ignition switch in the OFF position.
4. Close all the vehicle doors.
[ol][/ol]
5. Unbuckle the driver's safety belt.
[ol][/ol]
6. Place the parklamps/headlamps switch in the OFF position. (If vehicle is equipped with Autolamps, this will not affect the procedure.)
[ol][/ol]
[/align]Deactivating/Activating
1. Turn the ignition switch to the RUN position. (Do not start the engine.)
2. Wait until the safety belt warning lamp turns off (approximately one to two minutes).
[ol][/ol]
3. NOTE: Steps 3 through 5 must be completed within 60 seconds or the procedure must be repeated.
Buckle then unbuckle the safety belt three times, ending with the safety belt unbuckled. This portion of the procedure can be done before or during belt minder warning activation.
[ol][/ol]
4. Turn the parklamps/headlamps on then off.
[ol][/ol]
5. Buckle then unbuckle the safety belt three times ending with the safety belt unbuckled. After this step the safety belt warning lamp will be illuminated for three seconds.
[ol][/ol]
6. Within seven seconds of the safety belt warning lamp turning off, buckle then unbuckle the safety belt. This will enable the belt minder if disabled or disable belt minder is enabled.
[ol][/ol]
7. The following sequence of events confirm the belt minder is enabled:
flashing of the safety belt warning belt lamp four times per second for three seconds
three seconds with the safety belt lamp off
[ul][/ul]
flashing the safety belt lamp four times per second for three seconds again
8. The safety belt lamp flashing four times per second for three seconds provides confirmation of belt minder disabled.
[ol][/ol]
9. After confirmation, the deactivation/activation procedure is complete.
[ol][/ol]
Old Nov 14, 2007 | 11:03 PM
That is very in depth i will try tomorrow and let you know Thanks for the help.
Old Nov 15, 2007 | 09:39 PM
Worked great thanks for the help
Old Nov 15, 2007 | 10:06 PM
Glad you got it squared away...
Old Nov 16, 2007 | 01:53 PM
Bullitt94's Avatar
That's good stuff. I may have just pulled the fuse...[8D]
bubble0304
Oct 18, 2012 10:01 AM
JARS8078
Nov 16, 2008 10:33 AM
hdvespa
Jul 8, 2007 11:07 AM
hdvespa
Apr 20, 2006 06:40 PM
ejb11
Dec 14, 2005 02:12 PM
