2005 F350 Dually, NEED CODE TO TURN OFF SEAT BELT BUZZER AND LIGHT
Old Nov 15, 2008 | 04:59 PM
JARS8078's Avatar
Default 2005 F350 Dually, NEED CODE TO TURN OFF SEAT BELT BUZZER AND LIGHT
Hello i was seeing if anyone knows the code to turn off seat belt buzzer on F350 2005 dually 4WD? i put seat belt on and it still buzzes at me so i just want to turn it off. Please help
Old Nov 15, 2008 | 05:29 PM
Default RE: 2005 F350 Dually, NEED CODE TO TURN OFF SEAT BELT BUZZER AND LIGHT
Belt-Minder Deactivating/Activating
[/align]Preparation
[ol][*]Before deactivating/activating the Belt-Minder, apply the parking brake.[/ol]
[*]Place the gearshift in the PARK (P) position (automatic transmission) or the NEUTRAL (N) position (manual transmission).[/ol]
[*]Place the ignition switch in the OFF position.[/ol]
[*]Close all the vehicle doors.[/ol]
[*]Unbuckle the driver safety belt.[/ol]
[*]Place the headlamp switch in the OFF position.[/ol]
[/align]Deactivating/Activating
[ol][*]Turn the ignition switch to the RUN position (do not start the engine).[/ol]
[*]Wait until the safety belt warning indicator turns off (approximately 1 minute).[/ol]
NOTE: Step 3 must be completed within 50 seconds after the safety belt warning indicator turns off.At a moderate rate, buckle then unbuckle the driver safety belt 9 times, ending with the safety belt in the unbuckled state.
[*]After this step, the safety belt warning indicator illuminates for 3 seconds.[/ul][/ol]
NOTE: The buckle/unbuckle sequence may not be counted if completed too fast. Wait approximately 2 seconds after each sequence.Within 10 seconds after the safety belt warning indicator turns off, buckle then unbuckle the safety belt.
[*]This disables the Belt-Minder feature, if it is currently enabled. As confirmation, the safety belt warning indicator flashes 4 times per second for 3 seconds.[/ul]
[*]This enables the Belt-Minder feature, if it is currently disabled. As confirmation, the safety belt warning indicator flashes 4 times per second for 3 seconds followed by another flash sequence of 4 times per second for 3 seconds.[/ul][/ol]
[*]After confirmation, the deactivation/activation procedure is complete.[/ol]
Old Nov 15, 2008 | 05:35 PM
JARS8078's Avatar
Cool thanks alot. another question while im here. How do you change or even figure out what the door code is on outside of door to unlock doors?
Old Nov 15, 2008 | 06:16 PM
The belt minderand the door program/code changing information is in the owners guide, and there 'should' be a white code card (default code) in the handbook if it is still there?
Old Nov 16, 2008 | 10:33 AM
techford's Avatar
Hi, if don't have the factory code of the keypad, you will need to go to the dealer to have it scan. Then, you will be able to add more codes that you want. Whatever, there is no way to erase the factory code, except by replacing the module, so don't give that code to anyone.
Nic.
bubble0304
Oct 18, 2012 10:01 AM
jessepatten
Jan 12, 2010 04:54 PM
93f250xlt4x4
Aug 23, 2009 06:11 PM
ejb11
Dec 14, 2005 02:12 PM
