Small clunk or click when first applying the brakes
Old Mar 9, 2018 | 09:59 AM
Fordguy581's Avatar
Default Small clunk or click when first applying the brakes
Hello everyone first time on the forum.
My dad asked me to take a look at his truck, a 2006 f150 5.4L 4x4. It makes a small clunk when applying the brakes (only at low speeds like 5 - 15 MPH) and when going over speed bumps (not every time, maybe half of the time), it has about 118k miles on it. I thought it was the sway bar bushings and/or links but the sway bar doesn't move even with a pry bar. The click or clunk also happens during acceleration. I haven't been able to find out what it is yet. Also the ball joints, control arms and tie rods are solid, no play at all. Any help would be very much appreciated,
thanks,
Paul
Old Mar 10, 2018 | 03:46 AM
Does it occur when only in 2 wheel drive or also in 4 wheel drive?
Might be a good idea to check all the u-joints starting with the front axles and drive shaft. Then check the rear driveshaft u-joints and drive line.
Old Mar 10, 2018 | 06:46 AM
Fordguy581's Avatar
I'll check if it does it in 4 wheel drive and I'll let you know. The driveshaft makes a small clunk when you put it in to gear, so maybe that's part of the problem.
Thanks,
Paul
ptotoole
Nov 30, 2017 09:44 AM
billj818
Oct 23, 2017 07:14 AM
vaultdweller
Aug 12, 2017 03:15 AM
Fourder
Oct 17, 2013 08:15 PM
jason
Jul 21, 2005 01:10 AM
