swapping 4.2L engine
Old Nov 25, 2012 | 01:00 PM
webwiz's Avatar
Default swapping 4.2L engine
Hello,
please excuse the newbie(me).
My question is simple(I think)
I want to know if I can pull the 4.2L out of a 1999 F-150 and put in my 1998 E-250 (both have the 4.2L V6 engine and both have AT
Everything should bolt up the same right??
Thanks so much
SB
Old Nov 25, 2012 | 03:07 PM
way2old's Avatar
It should be a straight forward swap. I think all the mounts and wiring are the same.
Old Nov 25, 2012 | 05:17 PM
webwiz's Avatar
Thanks, I was thinking so too...
But two or three heads are always better than one...
Im guessing that except for bringing the dipstick and oil filler out of the doghouse(E-250)
everything should be ok...
Thanks again
Old Nov 25, 2012 | 06:44 PM
greasemark's Avatar
The engines are very much the same; however, do make a through visual check of the mounts. Something sticks in my mind about there being a difference, but that could just be insanity.
While it's out, and it being from an E series, are you going to reseal it? It's probably leaking something from somewhere (front cover, front/rear crank, oil pan, etc.)
Old Nov 25, 2012 | 10:59 PM
webwiz's Avatar
If the Blocks are the same but the mounts different shouldnt I be able to swap mounts as well??
Yes, I may go ahead and just rebuild the old engine as a backup unit or sell it...and recover some of my cost...
SB
Old Nov 28, 2012 | 01:09 AM
seanzacari's Avatar
You can swap these but you should take help of an expert for doing these because if not done properly it can create leakage.
bls_svcs
Mar 14, 2013 05:18 PM
webwiz
Nov 25, 2012 10:34 AM
yosef
Jul 20, 2012 04:27 PM
DGrason
Feb 17, 2007 08:09 PM
freddie_nhs_07
Jul 30, 2006 05:24 PM
