throttle response
Old Jul 12, 2017 | 03:40 PM
easyrydr's Avatar
Question throttle response
I would like to know if it is possible to something on my 06 5.4 truck 4x4
better throttle response? my truck is fine but it just seems like it needs better response. thanks
Old Jul 12, 2017 | 07:56 PM
Before suggesting anything, there are a few things we should know.
What kind of maintenance has been done to the vehicle?
A little more detail like , does it happen at any and all speeds , engine warmed up or cold,
The 5.4 is big enough to provide plenty of power under most conditions.
Miles on the odometer, are you the original owner , something like using other than the recommended motor oil can cause accelerated wear of critical parts, etc. So, can you help us out with addl info?
Old Oct 11, 2017 | 02:53 AM
paulpaul112's Avatar
If you want to increase throttle response, I would suggest using a tuner. Its the best way to increase throttle response in my opinion. Just make sure you get a decent one like the SCT x4 or something. An after market cold air intake will also increase throttle response by allowing the air to flow quicker to the engine. I wouldn't bother with an upgraded throttle body until you have these two upgrades done. If you want to find out more about the SCT x4 handheld tuner, just click HERE.
Hope this helps.
Tribalbear
Sep 18, 2012 09:54 AM
88 f-150
May 9, 2010 09:21 PM
shanes 04
Nov 20, 2009 12:27 PM
superduty2002f250
Dec 26, 2007 05:45 PM
ESCORTSRUS1989
Jul 4, 2005 01:06 PM
