Torque specs for f150 4.6 2007 Intake Manifold
Old Nov 22, 2019 | 10:05 AM
F150-07-4.6's Avatar
Default Torque specs for f150 4.6 2007 Intake Manifold
Hi working on my f150 Intake and have the shop manual but it's very vague. Can someone help with the toque specs for this.. Thanks in advance. i had to destroy 1 bolt then order all new bolts as they seem to be starting to rot. New intake manifold also. Have to drill and tap out one hole.. arrghhhhhh.
Old Nov 22, 2019 | 01:17 PM
Install the manifold bolts loosely ,then tighten the intake manifold bolts in the sequence pictured.
Tighten to 89 lb-in.....
Old Nov 23, 2019 | 02:26 PM
You mean inch pounds or foot pounds... just sayn. thanks again dude...
Old Nov 23, 2019 | 07:00 PM
lb-in = inch pounds
89 foot pounds,, gonna stretch some bolts
Old Nov 24, 2019 | 08:21 AM
raski's Avatar
If that is a plastic manifold, the spec has to be inch pounds. Don't know where this pound inch stuff comes from. 89 foot lbs will destroy a plastic manifold.
I would do it at 40 inch pounds first then take it to 89.
Old Nov 24, 2019 | 09:17 AM
Thanks guys, ur the bestest as usual...
Old Nov 24, 2019 | 09:54 AM
The abbreviation can be either way, lb-in ‘or’ in-lb.
Either way the meaning is one 12th of a foot pound...
Old Nov 30, 2019 | 08:26 PM
I got it going and runs great too, I had 2 vacuum lines crossed, There are 3 in the rear of the throttle body, I had the one with the triple into one reversed with the one on the top. Also I had # 7 injector wire that I must have loosened up when I was working on it. Now just wondering how much Antifreeze it takes. The auto parts place says 2 would be enough. Although it is full to where it should be it seems I have to add a bit to keep it on the full when cold level. I picked up a gravity tester and will test it tomorrow just to make sure I got most of the water out of it from flushing it a few times... Thanks guys for all your help once again........
Austyn2322
Feb 29, 2020 10:23 AM
stucky1945
Feb 20, 2017 05:08 PM
baconater357
Nov 7, 2016 11:09 AM
NetCommuter
Jul 10, 2008 08:57 AM
nybeat84
Oct 24, 2006 11:56 PM
