Trans Fluid Alternative
Old Mar 20, 2007 | 01:04 AM
81F150's Avatar
Default Trans Fluid Alternative
My transmission dipstick says to use ESP-M2C138-CJ fluid. I do not see any ATF in stores that references this number. I hear conflicting opinions about what is safe to use.
I have some HAVOLINE ATF that says it is safe for DEXRON II, IIE and III and I have some VALVOLINE MAX LIFE that says it is good for DEXRON III and MERCON.
Can I use one of these? If not what can I use?
Thanks for your help
Old Mar 20, 2007 | 01:29 AM
Default RE: Trans Fluid Alternative
Dextron III/Mercon is/was the service fluid for that application.. Mercon is being discountinued, and Mercon V will be the service fluid..
Old Mar 20, 2007 | 10:17 PM
goinstrong's Avatar
More stupid GM engineers made this fluid with graphite in it. If you ask me (having torn apart a lot of trannys.) the graphite seems to like to separate and wears seals out more. Old Fords ('79 andback) used type F fluid and had less overall buildup.
gcsmial
Jan 4, 2009 12:53 AM
ponyboys1022
Apr 9, 2008 10:12 AM
NEMESISACZ
Feb 17, 2007 03:59 PM
CHILAND
Jul 4, 2006 01:04 PM
bushman
Feb 17, 2006 09:39 PM
