Turbo Problem
Old Aug 30, 2021 | 07:54 PM
Rugerblue21's Avatar
Smile Turbo Problem
I have a 2012 Ford F150 FX4 V6 and is leaking antifreeze. I was told that it was leaking from the turbo. Over the past week or so the engine makes like a whistling sound on acceleration. Any ideas on if this is the turbo going bad? I was given a estimate of about 1700.00 for the repair. Thank you in advance for any suggestions.
Old Aug 30, 2021 | 08:07 PM
There was a known problem with the connection at the bottom of the degas bottle (coolant recover bottle) . The coolant would leak down the hose and wet the turbo, making one think the turbo had a problem. You might get another estimate for the repair . I believe the hose goes for around $100.00 plus labor.
Old Sep 1, 2021 | 01:18 PM
I had a diagnostic test done last year and was told that the coolant was leaking from the left hand turbocharger and coolant supply tube assembly and now the whistling sound is getting a little louder upon acceleration.
Old Sep 1, 2021 | 01:41 PM
A good part of the time , a whistling sound from turbo area is caused by a loose hose clamp allowing boost pressure to leak out and cause the whistle.
It is not that you can't effect repairs, but best left to a shop with experience because if there is more involved ,they should be able to handle it.
Ryan Lewis
Feb 11, 2020 11:55 AM
AnitaL
Jul 3, 2018 07:51 PM
D-Bar
Aug 23, 2012 07:25 PM
Mrxr6_menace
May 21, 2008 06:24 AM
bauer123
Feb 7, 2008 10:46 AM
