Turn signal issue
Old Jun 21, 2024 | 09:25 AM
BruceA's Avatar
Default Turn signal issue
2018 F150 XLT. All signal lamps work, but when using left turn signal dash light blinks much faster and sound is different. Right side and flashers seem to be just fine. I've read these trucks no longer have flasher relays and it's all controlled by the BCM. Could this be a turn signal switch issue?
Old Jun 21, 2024 | 10:37 AM
When you say all signal lamps work, are you sure the signal lamp flashing is the correct element in the bulb?
If there is a poor ground in the fast flashing direction , it could be using the other element in the bulb..
Old Jun 21, 2024 | 10:43 AM
BruceA's Avatar
I'll switch out the bulbs to make sure thats not the issue.
Old Jun 21, 2024 | 04:23 PM
The bulb may not the problem, usually it is a poor ground available to that circuit.which could be either the front or the rear.
BruceA
Jun 21, 2024 09:17 AM
hokiejuke
Jun 16, 2021 02:34 PM
Bigdigger
Sep 9, 2019 04:00 PM
Tslayer
Apr 3, 2015 08:21 AM
grandmarquisNM
Jul 21, 2012 10:30 AM
