Water in air filter housing. 1984 300 L6
Old Feb 22, 2019 | 07:53 PM
dakelley62's Avatar
Default Water in air filter housing. 1984 300 L6
I am finding some oil in the air filter as well as water in the bottom of the housing. I have changed the pcv? valve as well as the crankcase ventilation filter and still getting a little water after driving less than 5 miles. Any ideas of what is going on? Thanks in advance.
Old Feb 23, 2019 | 07:37 AM
You did not mention anything about the mileage on the engine/vehicle.
It does sound like the engine is puffing more compression into the air filter housing than the PCV system can take in.
Old Feb 23, 2019 | 05:18 PM
dakelley62's Avatar
I do not know for sure how many miles on it as I bought it 6 or 7 years ago and the speedometer and odometer were disconnected. I would guess about 140k. Does it sound like the pcv system is in need of repair? This really concerns me. Thank you.
Old Feb 24, 2019 | 03:28 AM
What might be considered,
If a compression test were done , it would provide some info on if the engine had lots of wear for instance.
If that was the case you would have a better idea of just where you stand and that no amount of small parts replacement will do any good.
Once that was done , depending on what results were obtained we move on to other areas.
It would not make much sense to throw parts at a worn out engine. I would either have that test done or do it myself.
What do you think?
Old Feb 24, 2019 | 08:12 AM
dakelley62's Avatar
I will have the test done. You make a good point. Thank you.
Javier250
Jun 18, 2019 10:08 PM
Joe Reeves
Jul 14, 2017 07:19 AM
gags61
Jul 30, 2007 04:32 PM
focusman
Nov 21, 2006 12:59 PM
fipsy
Jan 17, 2006 04:53 PM
