What Module Do I Need?
Old Oct 30, 2022 | 05:01 PM
manifold's Avatar
Default What Module Do I Need?
Thank you to anyone who can help me with this -
I have an 09 F-150 xl 4wd 5.4L VIN 1FTPX14V19FB04688
The back windows are down and don't roll up
The front window are up and won't roll down
Door locks don't work
All a/c and heater functions don't work
I'm sure there are other issues. These are the ones that are dominant and visible
One source tells me I need a Body Control Module (BCM)
Another source say a Central Processing Unit
What module or modules do I need to fix this? Or do I need to provide more information?
Again, thank you.
Old Oct 31, 2022 | 05:42 AM
Before replacing anything, a good scan tool will run a module health check and you can go from there.
Old Oct 31, 2022 | 06:48 AM
manifold's Avatar
Thank you for the reply.
I have an OBD 2 reader that showed there were no codes stored even though the check engine light is on. I thought maybe the meter is defective so I ran it on my Ram truck which I know has a few codes. It showed those codes the same as I got when I took it to Auto Zone for a reading. I thought it was odd there are no codes stored and maybe that is just another glitch with the issue. I'll take the truck for a reading somewhere else to see.
Thanks again.
Old Oct 31, 2022 | 01:38 PM
manifold's Avatar
I took it down and had it read at auto zone and the only code is P0150 which it states is an o2 circuit. There are no other codes.
manifold
Oct 29, 2022 07:59 PM
mmotz
Jun 3, 2021 05:26 AM
cngizbleevng
May 18, 2020 07:02 PM
cngizbleevng
May 18, 2020 01:37 PM
