01 F350 V10 starter relay
Old Jan 12, 2008 | 06:19 PM
ad2jiffy's Avatar
Default 01 F350 V10 starter relay
My truck will not start. Is there any way to check the starter relay to tell if it is that or my starter or something else. I have checked all the fuses and they are OK.
Old Jan 23, 2008 | 02:53 AM
b rabbit's Avatar
Default RE: 01 F350 V10 starter relay
yeah have someone try to start it and see if it clicks if it dosen't switch it will the fan relay and see if it starts , for the starter you could get a multimeter from autozone and put one lead on the positive post of the batt and the other on the stater batt terminal the one with the red battery cable going to it. see if you got batt voltage to it. havesomeone crank it and see if the voltage drops if it does replace the stater .also visual all the wire see if anything is unpluged. so i asumeing you car won't crank at all. have you checked you batt voltage. does your radio and other accessorys work?
JDEdmo
Apr 5, 2022 04:03 AM
bosanci28
Apr 17, 2010 11:33 PM
Raheel
Jul 2, 2008 05:48 AM
rlevy64614
Aug 12, 2007 05:18 PM
dettmer
Jul 4, 2007 08:07 PM
