04 F-250 starts to buck when going up small hill
Old Feb 10, 2007 | 07:25 PM
Stangman's Avatar
Default 04 F-250 starts to buck when going up small hill
ok here it goes guys... I have an 04 diesel that is giving me some problems.. I pull a 20 ft trailer eveyrday that is pretty loaded down. when i go up a hill at around 55 to 65 mph and the rpms are at 2000 to 2400 when i feel the truck needs to down shift it doesnt and black smoke just pours out and it almost feels like it blew an intercooler pipe and then after i let off it will down shift and sometimes climb the hill and sometimes it does it the whole time while climbing the hill, i have the tow/ haul on and the truck is completely stock.. anyone have any suggestions
Old Feb 11, 2007 | 08:25 PM
Stangman's Avatar
Default RE: 04 F-250 starts to buck when going up small hill
oh come on now guys, i know someone has got be havin the same problem or have heard about it.
[align=right] [/align]
Old Feb 11, 2007 | 09:35 PM
Any CEL during you running concern?
Old Feb 12, 2007 | 01:08 AM
Stangman's Avatar
well it threw one that night, but when i went and started it up the next morning it was gone, you think the computer still has it stored
Old Feb 12, 2007 | 02:33 AM
If you could have someone read the memory code/s it would be a help, and is always a starting point for performance/running concerns.. Some of the parts vendors have code readers and will do it for free Autozone ect..
Old Feb 20, 2007 | 01:39 AM
1954ford's Avatar
sound to me like you've probably got a sticking turbo vanes, you can remove the turbo to clean these vanes but it's not an easy job, so i'd take it to the dealer if i was you
Old Aug 10, 2009 | 08:29 AM
ok100's Avatar
Default Has problem been solved?
I have the same issue on an 04 and 05. did someone resolve the problem? Also does it when I step on the throttle and let off quickly.
Old Aug 15, 2009 | 08:42 PM
JTGrant1's Avatar
When it puts out alot of black smoke it is one of 2 things- either you have got dirty injectors and its getting to much fuel under load, or like was already said you are not getting enough air. The first thing i would do is check your charge air cooler (looks like a big radiator going to the turbo), and see if it has anything blocking air flow, or if it has a leak somewhere. you can do this yourself. If thats not it than ide do a tune up, and get the injectors and turbo cleaned. Try those things and let me/ us know what happens.
goatsauce
Apr 15, 2013 08:32 PM
snapper1d
Dec 10, 2010 09:26 AM
jataos
May 4, 2009 02:04 PM
chikkie007
Jul 24, 2007 11:59 AM
250 Black
Jul 7, 2006 03:41 AM
