1969 F250 Lights Problems
Old Dec 27, 2014 | 07:39 PM
Rico Tesio's Avatar
Default 1969 F250 Lights Problems
My turn signals come on but stay lit. They do not blink. I replaced the fuse and it worked for about 30 seconds before the same problem came back
Second problem. My headlights work on dim but as soon as I press the floor button to turn them to high beams, they go out completely.
I'd like to have the entire truck rewired, but I'd like to get it operable first. Any suggestions would be appreciated.
Old Dec 27, 2014 | 09:55 PM
Thumbs up
Welcome to the site..
If both sides R&L don't flash, good chance its the flasher unit.
The dimmer switch is a common failure and could be the cause for the no high beams. Also, the connector at the dimmer liked to corrode. You can test the light functions bridging the connector before replacing the switch.
willy j
Oct 9, 2025 03:02 PM
Joseph Bunch
Sep 10, 2022 03:11 AM
austinbarton1
Jun 27, 2013 02:08 PM
Mrmr
Apr 27, 2013 11:28 AM
cu101man
Feb 1, 2010 11:35 AM
