1989 5.8 L F-250 won't stay running
Old Jul 2, 2011 | 02:19 PM
Jstew's Avatar
Default 1989 5.8 L F-250 won't stay running
First off, I am just learning how to work on this thing and I need a lot of help. The truck will not run. I can get it started but it quickly dies. When It is running and I press the gas it bogs down. I have replaced the plugs and wires, the IAC, the air filter and the fuel filter. I don't know what else to do. Please help!
Thanks
Old Jul 2, 2011 | 04:33 PM
Jstew's Avatar
If I let it sit for a bit it will start right up and run for about 10 seconds and then die again. after that I can't keep it running
Old Jul 3, 2011 | 01:48 PM
Gary2Wheels's Avatar
It could be any number things....have you checked to see what code #'s come up when you 'read' the computer?..that may give you clue.I would checked fuel filter & pump as an old school guess...they're located under the truck along the inside of the driver's side frame rail.
Old Jul 5, 2011 | 11:46 AM
Jstew's Avatar
I replaced the fuel filter but haven't taken a look at the pump yet. I will try that next. I don't really have a way to hook it up to a computer
Old Jul 5, 2011 | 02:28 PM
the fuel pumps rearely go bad,but carefully inspect the wiring from the harness to the pump.The blade terminals can get loose,dirty,or otherwise faulty.
jkkay
Feb 24, 2021 03:39 PM
fiestyfeista
Mar 12, 2015 11:51 PM
rmcard
Dec 17, 2006 06:30 PM
cruzandkathy
Jul 30, 2006 04:04 PM
chaumer
Feb 20, 2006 03:37 AM
