1989 ford f250 5.8 issues
my truck was surging at idle.cold and warm.Now just starts and dies.ive replaced intake gasket and plenum gasket.Idle air control valve,throttle position sensor,map sensor,coil,ignition control module,cap and rotor,spark plugs,Ecm,still no change PLEASE HELP.
yes it will rev and drive the road the idle is the only issue at this time.i also replaced coolant temp sensor.I havent checked fuel pressure since i first started working on it.It was right around 40psi with key on.The exhaust also smells like its running very rich.
