1995 Ford F-250 XLT
Old May 24, 2022 | 02:21 AM
WEASE1718's Avatar
Default 1995 Ford F-250 XLT
1995 Ford F-250 5.8L 351 Windsor 140,000 Miles
going to give you guys the whole run down what happened today so we rule everything as possible out!
“Ms.Rosey” As I Call Her Is My Truck Well She Was Running Like A Top Then
this is what has happened to me. I was driving down the road and out of no where my trucks engine just shuts off. So I think maybe no gas (can't be, just put 5 gallons in). I have power, but I do not hear my Fuel Pump primping on for 2 seconds as I turn the key. So I went and bought a new Fuel Pump. Installed it and everything was good for about 2 hours... and then it just stopped working again... (I was stuck at Goodyear) they tested the 3 wires just above going to the fuel tank (Black, Grey, Purple). Black Read .00volts, Grey Read 4.6-4.7volts, Purple Read 4.6-4.7volts. So then they used some test thingy that put volts to the Grey Wire, Read 12.(something)volts and I could hear the fuel pump turning on. So we tried cranking the engine over while they put power to the pump (with the tool they used) and still nothing! (Tried that multiple times)
So I figured to myself... The fuel pump must be good since its working but its getting not enough volts... Because it needs around 12 volts to run... But it was only getting 4.6volts. So I figured it was the wiring in the fuel pump housing... So I warrantied out the fuel pump for a new one and decided this time to replace the wires that the new fuel pump always come with... So I had to place 2 connectors (The one on top of the fuel pump housing and the one that goes to the fuel pump) I replaced the Grey (signal/power "i think") and Black (ground "i think") wires. I had to cut the Black wire because it was grounded by solder. The wire (Black) that was grounded to a fuel line on the fuel pump housing I had to cut in 2 ends because of how it was like grounded in a split. So I had to solder (My first time soldering, it was a little clumpy but still the wires where stuck on, seemed like a good connection, also gave it a good tug and the wires are nicely on there. Heat shrunk it after) So I plugged the Black wire in the A Connector terminal on the connector that goes to the fuel pump. Thats what the instructions said. And the Grey wire into the B Connector terminal on the connector that goes to the fuel pump. Made sure that the Black wire is plugged into the right terminal on the fuel pump housing connector that has the floater unit (Purple wire) on it. And the Grey wire in its correct spot on that connector also.
Finally I'm happy, that **** to me 2 hours to do. So I put the fuel pump back it and instead of just twisting and taping the 3 wires that I cut to get the fuel pump housing off (wires coming out of the top of the fuel tank). I butt connected and heat shrunk them. Just to be nice and good Also I was checking the wires and connections on the fuel pump housing and they all appear good. FUEL PUMP IS IN! Also went and bought and new Fuel Pump Relay just to waste money and be on the good consious side! Everything is ready to go!
So I go to turn the power on waiting to listen for the Fuel Pump to prime 2 seconds telling me that I did an AWESOME job and... NOTHING HAPPENED!
So... Now... this is all I am doing right now
I left it alone for a couple hours and came back and tried multiple times to start it... I HEAR 2 Clicks About 5 seconds apart and a pop noise coming from throttle body! It cranks but no start...
What in the world can that be!!
WEASE1718
May 27, 2022 11:24 PM
Jarrett Jenkins
Feb 12, 2018 03:45 PM
Naovilla1
May 21, 2017 03:56 PM
Clgrein
Jun 22, 2014 04:59 PM
manicmachanic
Dec 13, 2008 09:20 PM
