fuel pump question
Old May 21, 2017 | 12:09 PM
Naovilla1's Avatar
Default fuel pump question
Ok 2000 f150 v8 5.4 triton not getting fuel started and died with starter fluid, relay clicks, fuel filter clear, power to pump, back probed fuel pump connector to 12v and it turned on twice with a lower tone than normal and wont turn on anymore when back probing even out of tank. It was hard start at first had to push down on gas to help it out, no prime every time it didnt start now it cranks no start at all. So i think it could be fuel pump I ordered the motor or idk what its called cylinder at bottom of FP bc the assemlbly is ok but i also noticed wires to the fuel regulator is black as if it could be shorted idk, is this normal? Would it affect the FP at all its not a the main wires but wires to the fuel level mecanism. Having trouble posting pic but its the two "brain" wired not main power wires one yellow goes to the fuel level mecanism and the other is pink and orange seems kinda like a ground wire but probably not idk it connects by a bolt to the frame where the fuel level mechanism sits hope someone can understand what im talking about
Old May 21, 2017 | 12:12 PM
Naovilla1's Avatar
Also this model does not have FPDM under spare. Also inertia switch not tripped and dry at Schrader valve
Old May 21, 2017 | 01:07 PM
When you first turn the key on you should hear the fuel pump run for approx. 2 seconds.
Do you hear that?
The PCM(computer) turns it on for 2 seconds by grounding the fuel pump relay.
If you don't hear it, you need to confirm power and ground at the fuel pump module in the tank. If you have a good ground (cleaned and tight) and have power at the pump it should run. The PCM gets an RPM signal when cranking from the crank sensor and allows the fuel pump relay to close providing power to the pump assy. Depending on what you find will determine your next move.
Loads of good fuel pumps get replaced because good grounds and power were not confirmed and then the connections get checked.
Old May 21, 2017 | 03:32 PM
Naovilla1's Avatar
It doesnt prime and i know there was 12v there how do i test for ground again? There is a ground wire on the harness for the float arm thing that seems to be shorted out would that cause it to not work?
Old May 21, 2017 | 03:56 PM
What do you mean by shorted out?
If you suspect a poor ground and don't have the equipment to check and confirm that , Just run another piece of wire from a good clean ground to the ground wire in question.
jozepy24
Jul 13, 2019 05:21 AM
fordexpedition2006
Apr 21, 2017 05:23 PM
Spaznaut
May 24, 2014 02:10 PM
shad9876
Sep 17, 2007 10:52 AM
Flattire Fred
Jan 16, 2007 10:16 PM
