1996 F350 Battery Level Low
Old Dec 14, 2016 | 08:59 PM
Mwalton's Avatar
Exclamation 1996 F350 Battery Level Low
I have a 1996 Ford F350 before I start it up and I turn the key forward the battery level is very low I just replaced the two batteries last night. We did an alternator test when I got the batteries and the test showed good. Once it starts up and sits running for around a minute it jumps to around 14 V where it should be. I'm at a loss I have no idea what is wrong with it I live in Michigan and the next coming weeks is going to be very cold around 10° and even lower, after it sits overnight or after I get out of school The battery level is so low when I turn it over it sounds like it's going to die, I just replaced the glow plugs and the glow plug relay so now I want to fix the battery problem. Please someone help soon
Old Dec 15, 2016 | 05:09 AM
Sometimes the battery cables can look OK and be corroded internally. The better way to confirm condition is with a voltage drop test. And while doing that it would be a good move to have the starter draw checked. The connections from the alt output cable to the batteries should be checked also. If there is corrosion (seen or unseen) in that wiring, battery charging can be affected. Mileage and time have a way of allowing problems to grow in cold damp conditions.
surferjoegomango57
Dec 11, 2013 02:32 PM
Michael Leonard Woodcock
Dec 10, 2012 08:36 PM
stevenjames
Feb 10, 2009 07:58 PM
lion35
Oct 22, 2007 03:29 PM
bkiyota
Nov 29, 2005 10:27 AM
