1996 no start
Old Dec 22, 2008 | 11:28 PM
Justinlogs's Avatar
Default 1996 no start
I have a 1996 powerstroke hat cranks but will not start - i have checked several things that i have read about on different forums such as all fuses and maxi fuses , all good - fuel bowl heater - glow plug harness and relay - and replaced the cam sensor - any input on further diagnosis would be a great help
Old Jan 1, 2009 | 10:58 PM
marks460's Avatar
Default RE: 1996 no start
hi, does the oil pressure gauge come up within approx. 10-15 seconds of cranking if not then it could be a faulty IPR valve or a internal(injector orings or injector) high pressure oil leak-does the engine smoke out of the exhaustwhile cranking- if so then you are getting high pressure oil and fuel to the engine-it should start(if everything you checked is good)-if not then you will need a scan tool to check the IPR oil pressurereading from the ICP sensor-this will take a proffesional to check,mark.
alanjlee
Oct 25, 2012 07:15 PM
fw31100
Sep 21, 2008 08:13 PM
rye56
Aug 20, 2008 04:07 AM
jocasio
Dec 19, 2007 09:28 AM
