1997 f250 seems like its having a misfire shake at low rpm between 45 and 55
Old Apr 22, 2020 | 05:53 PM
1997f250's Avatar
Default 1997 f250 seems like its having a misfire shake at low rpm between 45 and 55
Truck starts and idles fine drives ok until about 45 when it shifts at a low rpm it wants to shake like a misfire, but if you were speeding past that point there is no shake. I have changed the spark plugs, wires, cap, rotor, button , ignition coil, map sensor o2 sensor and it still does it. Any ideas would help thanks in advance.
Old Apr 23, 2020 | 05:46 AM
Are you sure it isn't a problem with a questionable U-Joint in the driveline?
Old Apr 23, 2020 | 06:05 AM
1997f250's Avatar
I got under the truck and nothing is loose. It only happens right after a shift at low rpm. If I left off it stops and let it down shift it drives fine through it just won't ride at like 48 mph without engine shake.
Old Apr 23, 2020 | 08:12 AM
If you power brake the engine in gear at different throttle positions and the engine starts to break down, I would agree , an engine problem. If you cannot get the engine to misfire or break down power braking it , then I would suspect a driveline problem.
Old Apr 23, 2020 | 08:15 AM
1997f250's Avatar
Ok I will give it a try. I just had brand new tires ball joints and an alignment done 2 weeks ago. Where should I start at.? When it starts shaking it feels like a misfire cause pushing the gas doesn't help
Old Apr 23, 2020 | 08:17 AM
1997f250's Avatar
Old Apr 23, 2020 | 09:49 AM
How about if you bring us up to speed ?
Was the problem present before you had tires, ball joints and alignment done?
Old Apr 23, 2020 | 10:29 AM
Does it occur if OD is canceled out?
Old Apr 23, 2020 | 11:21 AM
1997f250's Avatar
Yes it was happpening before tires and ball joints. What are you referring to with the od canceled out. Over drive?
Old Apr 23, 2020 | 01:24 PM
Yes,,,
