1999 f250 diesel chattering
Old Feb 23, 2007 | 05:58 PM
  #11
2ManyTrucks's Avatar
Default RE: 1999 f250 diesel chattering
Great Explanation on the Dual Mass Flywheel. I get it! I sincerely appreciate your time. Any chance that this rattling at idle could/would damage anything? I don't let it idle much because of the rattle?
Old Mar 15, 2008 | 04:31 PM
  #12
kwrusse's Avatar
It has been a while since your post. However, the comment manual transmission was used and it sparked my interest. I've got a 99 F350 7.3L Automatic that I just took in for the recall on the position sensor and the dealer told me it was too loud and my dual-flywheel was coming apart. So I went and listened. Told him it always sounded like that to me. He compared it to a newer truck that was ideling the had the insulated intercooler. I just told him, Good Try, I'll take it back home and put it away as soon as you do the recall. Question is, is there any way of testing it or visual inspection, or do I even have one?
Thanks
Old Mar 15, 2008 | 08:39 PM
  #13
If you have an automatic you have the 4R100 trans.. 99 was the problem year for the torque converter rattle, or whatsounds like a 'bearings in a can' rattle atidle.. With a torque converter (auto) you don't have a dual mass flywheel (manual).. Pretty easy to listen down low around the trans/bellhousing an hear the rattle.. Some can be worse than others, usuallydepending on mileage/use ect. but was a design problem.. You can testthe converter for the noise/condition by 'momentarily' grounding the converter clutch solenoid circuit (pin 54) P/Y wire on/at the trans connector and it'llapply the converter clutch(while grounded) and the rattle noise should stop.. If so, the fix is a replacement converter if the noise is excessive..
Old Mar 30, 2010 | 10:48 PM
  #14
elderivers's Avatar
I seem to have the same problem...but it sounds like its coming from the front of the engine. it has had the transmission and convertor replaced before i bought it...before 92,000 miles. i had to replace the front seal on the transmission about 4 months ago. the pulleys where checked and cleared...but the "bearings in a can" noise describes it perfect...it comes and goes, most of the time idling other times i can hear it stopped at a light...any ideas?
eohdtech
Sep 23, 2010 10:07 AM
SOMEBODYELSE
Jun 16, 2009 10:50 AM
bikerpawpaw
Feb 19, 2008 09:16 PM
wannarace777
Dec 7, 2005 03:44 PM
muellerranch
May 5, 2005 01:11 AM
