2000, F-250, Won't Idle
Old Dec 28, 2006 | 05:21 PM
davidsosis's Avatar
Default 2000, F-250, Won't Idle
I have a '00 F-250, 5.4L. Most of the time, the truck runs fine... HOWEVER, sometimes it just won't hold a normal idle. When this happens, the truck will idle around 400-500 rpm. Once the problem kicks in, it will remain for days. Sometimes, while this problem is happening, I could be sitting at a light and the engine will suddenly surge back to a normal idle. It's like a solenoid will suddenly click in. Does anyone have a suggestion as to what might be causing this problem???
Thanks,
Dave
Old Dec 28, 2006 | 09:43 PM
Default RE: 2000, F-250, Won't Idle
Any DTC's/CEL??
Check the IAC motor, if 'unplugged' the idle 'should' drop on a stable/spec. RPM,, if no difference on a lower idle or below spec.condition, thanthe IAC may bea fault, andfor a stuck/sticking EGR.. Try unplugging the vacuum hose on the EGR diaphram as well during an idle issue to see if EGR is being applied and not actually a valve issue.. Both can generate a lower than Spec idle... These would be 2 items I'd check straight off..
1. IAC
2.EGR
[IMG]local://upfiles/6756/2D48430B3A174BE58B5E875D2BD4B95A.gif[/IMG]
[IMG]local://upfiles/6756/A5D228A2EDB14D9C91B1FD5FF5444BCD.gif[/IMG]
Old Dec 28, 2006 | 10:53 PM
wheelsup68's Avatar
I could not agree more IAC it probably is, if not you waisted $65, then my next guess would be a possible mass air flow sensor, but the IAC makes more sense.
Old Dec 29, 2006 | 04:50 PM
davidsosis's Avatar
To all that may read this... and to the two kid people that had replyed to my request...
Just wanted to say "Thanks". I just replaced the IAC and believe that was the problem. The old one was near "COMPLETELY" blocked. The new one had no problem passing air through.
I replaced it and the truck seems to start and run fine.
Hope this solve will help others... :-)
Old Dec 29, 2006 | 10:48 PM
wheelsup68's Avatar
Glad to hear. Oh yeah what was the price? Was I close?
Old Dec 30, 2006 | 11:03 AM
davidsosis's Avatar
$39 @ Pepboys. What a deal.
Old Oct 6, 2007 | 05:44 PM
dreamweaver's Avatar
I need to replace my IAC for low idle problems. I purchased a new one but can't locate the old one on the eng. I have a 2001, F250, 5.4L 4x4. I looked at Hayapowers thumbnails but need more specific instructions. Can anyone Help. Thanks...
Old Oct 6, 2007 | 07:08 PM
Look on the backside of the intake elbow/throttle body..
[IMG]local://upfiles/6756/7EDBBF8336994C34A3BC4496BF49218C.gif[/IMG]
[IMG]local://upfiles/6756/00EE05DF334D45F4B11E72241B00E646.gif[/IMG]
Old Oct 7, 2007 | 07:58 AM
Thanks, I'll check it out.
Olpapa
May 18, 2008 03:22 PM
rippedrob420
May 29, 2007 10:06 PM
bae77345
Feb 21, 2006 12:26 PM
dap884
Sep 23, 2005 03:32 PM
1985crownvic
Aug 3, 2005 01:02 AM
