2000 F250 Regular Cab Trim
Old Mar 24, 2023 | 11:19 PM
Mobil's Avatar
Default 2000 F250 Regular Cab Trim
I have a 2000 F250 Regular Cab LWB. The trim on the top rear corners of the drivers and passengers side have come off leaving only the bolts remaining. I've gone and purchased replacement parts from Ford Motor Company and the parts do not fit - the bolt pattern is off by half an inch. Measured the distance between bolt holes and it's 3 5/8". The Ford Motor Company parts people have ordered 2 different sets and both would not fit the cab. They don't know what to do other than refund my money and call it a day. Anybody have any suggestions or recommendations on where I can acquire the correct Ford F250 Regular Cab trim parts?
2000 F250 Reg Cab passenger side missing trim. (Bolt pattern is 3 5/8" width)
2000 F250 Reg Cab drivers side missing trim. (Bolt pattern is 3 5/8" width)
Bought these new Regular Cab Trim parts from Ford Motor Company and they don't fit - bolt pattern is to short.
Any suggestions/recommendations on where I can find both cab trim parts that will fit this truck?
Old Mar 25, 2023 | 11:35 AM
Welcome to the site..
They should fit 99-07 Reg cabs.
There was an early/late trim where early were under the rear window rubber, late butted up to the glass edge. Not sure if that s the issue or diff.
You can install bonded trim pieces that are already painted to match. No issues with bolt spread or panel removal.
I'll check that part number,,,
Old Mar 25, 2023 | 11:51 AM
Part number seems accurate..
Whats the bolt spread at the 'base' of the new trim studs?
Old Mar 25, 2023 | 11:54 AM
Mobil's Avatar
They should fit 99-07 Reg and Crew cabs.
Thank you, please let me know what the part numbers are so I can get this repaired.
Old Mar 25, 2023 | 09:48 PM
Mobil's Avatar
3 5/8 inches
Old Mar 25, 2023 | 11:10 PM
The body holes are 3 5/8 and the studs 'at their base' are 3 5/8"?
Old Mar 26, 2023 | 06:44 AM
Mobil's Avatar
The holes in the cab are 3 5/8 inches spread apart per the Ford Motor Company Parts guy.
Sugashane
Jul 31, 2018 01:22 AM
BIGUN 63
Mar 11, 2013 03:08 AM
x-dj1990-x
Nov 16, 2012 06:33 AM
mpatch
Jan 16, 2011 08:34 AM
Ford Boy
Dec 31, 2005 04:58 PM
