Ford F-250 & Ford F-350The heavier duty full sized trucks from Ford, offering bigger, more powerful engines and drivetrains for the abuse they may go through in the workplace.
I have a 2000 f250 Superduty that has sat for a while. The speedometer now goes fine from 0 to about 15 and this jumps up to 75 and stays there. Can anyone anyone tell me what to check?
Since you never mentioned if your ABS (yellow) light stays on, I assume it proves out correctly during bulb check at start up. Also, do you know you have 4WABS (4-wheel abs) or RABS (2 rear wheel abs) or you are not sure?
Let's start from the easiest tasks first by cleaning the electrical connectors of your OSS and TSS. Clean both ends using electrical contact cleaner, if they are in poor condition, then use 91% isopropyl alcohol. Download the last 2 zip files to get their location and diagram.
If that doesn't help go over Pinpoint Test H, all those zip files are connector location and diagram needed on running pinpoint H.
