2001 f-350 7.3 deisel
Old Jan 11, 2008 | 06:44 PM
crs's Avatar
crs
Default 2001 f-350 7.3 deisel
Hello Guys,
2001 f-350 7.3
I have been getting a check engine light for some time , it tells me the glow plug are bad , it's the # 4 / #6 / latley the #8 / I changed out the first two but the light came back on in a short time ,it jumps around , I changed the harness under the valve cover, no change , I changed the valve cover gasketbecause the plug was not locking well , cleared the signals and the # 8 poped up as bad again . The dealer recomends changing the glow plug relay , around $230.00 , has anybody experianced this problem ? I would appreciate any feedback before buying the relay. Thanks
Old Jan 11, 2008 | 06:56 PM
Default RE: 2001 f-350 7.3 deisel
Is it always the same cylinder numbers that fail? Did it have any prior heat damage to the UVC gasket, or harness/s under the covers? Did you check the connectivity of the engine side harness connector terminals?any evidence of excessive heat there?
crs
Jan 11, 2008 06:56 PM
craigatkins
Mar 21, 2007 06:23 PM
ashlie112377
Feb 13, 2007 01:17 AM
ranchoruiz
Aug 1, 2006 03:28 AM
cinvest
Jul 29, 2005 01:42 PM
