2001 f250 7.3 idling high and like it's going to run out of fuel
Old Aug 17, 2017 | 09:32 PM
Brandon Kader's Avatar
Default 2001 f250 7.3 idling high and like it's going to run out of fuel
I have a 2001 f250 7.3. Recently started this problem idling at 1000 Rpms when stopped completely and when I let off the gas pedal it idles real funny like it's fixing to run out of fuel. It does not do this all the time however. At times it runs great. I had my mechanic scan it and at first it was the exhaust pressure sensor. Replaced it and it ran fine for awhile and it started doing again. Took it back in to get re scanned and it was throwing a bad ICM code. Replaced this as well and I'm still having the same problem. Had it scanned again and it's not throwing any codes now. I have no check engine light on and as long as I'm on the gas pedal it runs great. It's just when I roll up to stop or when I'm stopped completely. Again it does not do it all the time. Any help would be appreciated if anyone has ever had this issue. Thanks!
Old Aug 18, 2017 | 01:20 PM
eric hoffmeyer's Avatar
How is the fuel filter? Cap tight? Changed recently?
Old Aug 18, 2017 | 03:08 PM
About 6 months ago it was changed
surferjoegomango57
Dec 11, 2013 02:32 PM
hfb1957
Jan 8, 2013 08:03 PM
newyorker
Oct 28, 2007 09:17 PM
bud121156
Jun 27, 2007 12:10 PM
