2003 Ford F-250 5.4 131,000 miles warms up and bogs down
Old Dec 25, 2021 | 10:56 PM
Ahaarm17's Avatar
Default 2003 Ford F-250 5.4 131,000 miles warms up and bogs down
Hello I have a 2003 Ford F-250 5.4 131,000 miles has new motorcraft plugs and three new coils once warmed up and driving about 15 minutes it is bogging down fixed cat issue did plugs and the coils but still same issue my readings are
RPM-732
IAT-14
IGN ADV-9.0
LT FTRM1-25.0
LT FTRM2: -23.4
Maf(gr/s)—6.92
o2s11-0.325
o2s12-0.0
Old Dec 26, 2021 | 01:33 PM
Need the rest of the data stream info like STFT both banks , coolant temp etc.
Can you post the data when the engine is at 2000 RPM ?
Old Dec 26, 2021 | 03:41 PM
Ahaarm17's Avatar
STFT is -7 on both
temp was 189
Old Dec 26, 2021 | 07:08 PM
Would like to see all the info, but for now, I would look for why the system is attempting to reduce fuel injection time.
Old Dec 29, 2021 | 07:14 AM
raski's Avatar
RPM-732
IAT-14
IGN ADV-9.0
LT FTRM1-25.0
LT FTRM2: -23.4
Maf(gr/s)—6.92
o2s11-0.325
o2s12-0.0
I don't know where you are located but I am suspicious as to why your IAT is showing minus 14 or even + 14 degrees? Either case it is worth investigating.Also I can't tell but are your long term fuel trims negative or positive? Get rid of the dashes with your readings unless they are actually negative going.
Old Dec 29, 2021 | 11:19 AM
raski, Thanks for bringing out the dash problem. I completely overlooked that.
ERIK21788
Aug 29, 2019 12:25 PM
Adian226
Mar 17, 2019 05:42 PM
deelite852
Jan 8, 2019 02:18 PM
HARLEYBOY
Feb 1, 2009 02:09 PM
gashogf250
May 14, 2007 08:13 PM
