2004 6.0
Old Jun 6, 2019 | 02:44 PM
Tucker Mcqueen's Avatar
Default 2004 6.0
Hey guys so my truck is puffing grey exhaust fumes like crazy and rolling coal bad and it’s never done this before I checked my head gasket and had my codes ran for and injector issue and nothing came up can anyone help me
Old Jun 6, 2019 | 05:39 PM
ka9j's Avatar
Default smoking 6.0
Are you loosing any coolant? Did you have any error codes?
Old Jun 7, 2019 | 07:09 PM
Default 6.0
No I’m not at all and I was thinking it might be a head gasket and I’ve lost quite a bit of power like I’m not throwing any codes loosing any coolant or anything and I have no clue what to do but check my head gasket
Old Jun 7, 2019 | 08:28 PM
frankjr's Avatar
Default 6.0
If you're not using any coolant your head gasket is probably OK. Do you have a boost gauge on an 04? If so, is your boost low or normal?
Old Jun 7, 2019 | 11:21 PM
Default 6.0
No I don’t but I can’t tell my boost is low like I lost a lot of power with in the past 3 days
Old Jun 8, 2019 | 05:36 AM
bismic's Avatar
If you download ForScan Lite to a smartphone and buy an ELM327 OBDII adapter, you can see all engine parameters (including MAP sensor, EBP sensor, VGT % duty cycle, and Barometer readings). It is a very good code reader ....... many supposed code readers do a very INCOMPLETE job!
The information from the above sensors and actuators should help us troubleshoot..
Get readings at Key-On_Engine_Off, cranking (if possible), cold idle, and hot idle.
In the meantime, look to see if the VGT controller on the turbo is plugged in. The connector gets brittle easily (from the heat).
You might also check the EGR valve if yu still have an active EGR system. You could remove it to see if it (or the intake manifold) was plugged with solids.
Could also be a plugged turbo - the actuator ring that rotates the "variable vanes" on the turbine wheel might be plugged with carbon. The remedy for this is to remove, disassemble, clean, and re-install the turbo.
Old Jun 8, 2019 | 06:59 PM
ka9j's Avatar
Default ForScan vs. Torque
I use the "Torque" app for my phone. Is ForScan better than Torque or are they basically the same?
Old Jun 8, 2019 | 07:09 PM
bismic's Avatar
I like Torque better, but ForScan reads codes more thoroughly from my experience
Old Jul 6, 2019 | 09:37 PM
TheDon's Avatar
What was your outcome I'm having the same issue
Old Jul 8, 2019 | 09:26 AM
TheDon's Avatar
What was your outcome I'm having the same issue with my 04 6.0
