2004 F-250 No front or rear running lights
Old Feb 10, 2023 | 03:04 PM
  #11
kooterfoot's Avatar
Actually that would be awesome if you could do that
Old Feb 14, 2023 | 04:48 PM
  #12
kooterfoot's Avatar
I would like to see the views and if you would suggest a relay to use
Old Feb 20, 2024 | 02:38 PM
  #13
michael2326's Avatar
Default No running lights
Jumped the brown wires have running lights
what kind or relay needs to be wired in
Old Mar 19, 2024 | 09:59 PM
  #14
NORRILLOUS's Avatar
Default Similar issue
Originally Posted by outriggen
Okay so if you have verified all fuses, lightbulbs, and wiring and they all test good but you still have no running lights here is what I did.
1) Remove positive lead from drivers side battery.
2) Remove dash trim panel over fuse box if not already done.
3) Unbolt fuse box (CJB) 4 10mm bolts.
4) Locate black and grey harness on right side of the back. Pictures of what you are looking for below.
5) Locate brown wire in each, will be in the top row close to middle.
6) To test internal relay put a jumper wire across these while plugged in and turn light switch to auto or on position with the key on.
7) If you have running lights now you have confirmed that the relay is bad and you can purchase a replacement CJB or remove those wires from the harness and place them on an external relay.
I have similar issue but the jumper didn’t turn the lights on. What does that mean?
Corey Larsen
Feb 5, 2020 01:14 PM
MikeDirect
May 26, 2016 08:05 AM
lauraj
Sep 25, 2012 11:23 AM
catscan
Aug 21, 2011 06:55 PM
daschae
Jun 25, 2008 11:35 AM
