2005 F-350 6.0 AC Control Stopped Working
Turn your headlights on and off and see if the A/C controls return. If that doesn't work disconnect the batteries and then connect them back up. If either of these suggestions work, then the issue is with the battery saver relay in the Instrument Cluster.
i found a recommendation to start the truck, unplug the head unit, wait 10 seconds and plug it back in. That worked, at least for now.
It will keep happening from time-to-time. I find cycling the headlights works just as well.
Not a big deal to live with.
