2011 f250 cab bounce
Old Mar 12, 2023 | 04:49 PM
Jamcc85's Avatar
Default 2011 f250 cab bounce
I have a 2011 f250 CC long box and it seems after hitting bumps in the road the cab bounces quit a bit it causes the dash and everything to shake if i watch out the back window i can see the bouncing is related to the cab moving the box stays perfectly still if you sit in the box the ride is much smoother and you can watch the cab bounce up and down i believe my cab mounts may need replaced does anyone have experience in having cab mounts replaced and making a difference in ride quality the current bouncing is really loosening up things and making rattles And no way can you have a conversation if the road is segmented the cab seems to be moving to much.
Old Mar 14, 2023 | 10:46 AM
raski's Avatar
Could be as simple as over inflated tires, a seized shock or damaged bushings supporting the cab. Some things to check.
BIGUN 63
Mar 11, 2013 03:08 AM
x-dj1990-x
Nov 16, 2012 06:33 AM
builttough15_
Dec 21, 2008 10:12 PM
CW
Apr 15, 2008 12:05 PM
Ford Boy
Dec 31, 2005 04:58 PM
