2013 f550
Old Jul 13, 2020 | 04:25 PM
Large load's Avatar
Default 2013 f550
While looking for a wiring issue under my truck with a power probe , I probed the fuel sender Wire and now I don’t have a working fuel gauge. I’ve checked all the fuses and I can’t find one blown . Can anyone help me out ?
it’s a 2013 F550 6.7 4x4
Old Jul 13, 2020 | 05:03 PM
Welcome to the site.
Happen to know which color/tracer you back probed?
Put the IPC into test mode and see if the fuel sweeps.
To enter test mode, press and hold the message center RESET button. Then, turn the ignition switch to the RUN position and continue to hold the RESET button until the display indicates ENGINEERING TEST MODE, usually within 3-5 seconds. Next, press the RESET button once to advance through 'each' stage of the self-test. Stop at GAUGE.. All gauges will sweep as would the fuel and it would stop/set at the current fuel level. Sweep and reset?
If the gauges sweep,, you might with a meter, check the YE/VT for a signal/ref voltage input to the level sensor from the IPC.. Missing?
You may need to have to have the IPC checked for out of range code/s (Short to ground,, Open/short to voltage) if a fault is found..
Old Jul 13, 2020 | 06:00 PM
Large load's Avatar
Did I mention that I’m 58 and am clueless about what your abbreviations are ? 😂
Old Jul 13, 2020 | 11:06 PM
Which one ?
YE/VT- Yellow/Violet (VT being tracer color)
IPC-Instrument Panel Cluster
Old Jul 14, 2020 | 05:35 AM
A suggestion for what it is worth,
Checking anything on a vehicle with computers using a Power Probe is NOT recommended.There are circuits that if full voltage is applied ,they can be rendered inoperative AND expensive to replace.
If you can isolate the circuit from everything else you might be able to check for continuity. A test lite is good for confirming power present, but applying power to ANYTHING is asking for trouble..
Old Jul 14, 2020 | 05:40 AM
Large load's Avatar
[QUOTE=hanky;120145]A suggestion for what it is worth,
If you can isolate the circuit from everything else you might be able to check for continuity. A test lite is good for confirming power present, but applying power to ANYTHING is asking for trouble..[/QUOTE
this I found out to be true , the hard way .
Old Jul 14, 2020 | 09:24 AM
What was the result of the gauge sweep test?
Old Jul 14, 2020 | 05:35 PM
Large load's Avatar
I tried the sweep test , no good .
hold the reset turn key into run position and display bounces between 4x2 and low fuel that’s it .
Holli
Nov 12, 2017 08:58 PM
bmackinlay
Jun 5, 2014 01:47 PM
jersey girl
Apr 8, 2013 01:00 AM
trev0006
Jun 6, 2012 01:20 PM
