2016 f250 transmission issue
Old Feb 25, 2025 | 02:47 PM
Tonyg's Avatar
Default 2016 f250 transmission issue
What would cause the granny to not go in gear when temperatures are cold.
Old Feb 25, 2025 | 04:30 PM
Insufficient warm up. Next time after finishing a trip, park on a level surface and check your dipstick make sure the level is good.
Old Feb 25, 2025 | 05:38 PM
Tonyg's Avatar
It did finally start shifting through gears after it warmed up. I drove it about 10 to 15 minutes to town. I did check the fluid while it was in park on a level spot. It was full and clean not dark.
Old Feb 25, 2025 | 06:36 PM
If it was full and very close to the warm mark then the fluid level is fine. In the winter and after it's warmed up but before you drive set the parking brake and step on your pedal firmly, then shift to every gear and hold for around 10 seconds, keep this practice during winter time.
Old Feb 25, 2025 | 07:14 PM
Tonyg's Avatar
When you say step step on the pedal, are you referring to the gas pedal. To get the gears warmed up.
Old Feb 25, 2025 | 08:18 PM
Brake pedal.
Old Feb 26, 2025 | 08:26 AM
Tonyg's Avatar
That's what I thought you meant. I just wanted to make sure. Some people can be rude in ways
Old Feb 26, 2025 | 12:04 PM
BTW if yours is powerstroke diesel with turbo 6.7L or any cars with turbo, especially like those ecoboost with small engines 1.5L to 2.3L (smaller engines with turbo will put heavier load to the turbo), always warm up to prolong the life of the turbo, and don't rev over 2500RPM for the first 5 minutes. It's fun to drive a turbo car but it's not easy to maintain it. Doesn't matter it's in winter or summer time, doesn't matter if the temp gauge on dash shows it's close to operating temperature, just don't drive aggressively (rev hard) for the first few minutes.
Old Feb 26, 2025 | 05:52 PM
Tonyg's Avatar
6.2 liter gas. 4×4. We got it to pull our 28 travel trailer. 6 speed automatic transmission.
Old Feb 26, 2025 | 06:49 PM
Will need to check, but some ford trans had a temp sensor type flat spring that opened when temp rose to certain temp. Until this temp was reached shift scheduling was affected.
Will get back when I have an answer.
