4x4 Actuator
Old Dec 20, 2023 | 06:51 PM
Hardpivot's Avatar
Default 4x4 Actuator
I have a 2001 F350 7.3l with the electronic 4x4 selector, manual hubs and a ZF-6 manual transmission. A few years ago, my 4x4 stopped working. I replaced the switch in the cab but that didn't fix the issue. My suspicion is that the actuator on the transfer case is the problem, but I don't know enough about this system to be sure. Is there anything else between the switch and the transfer case that could be the problem? Is this a common issue with these models that has a common fix?
Old Dec 21, 2023 | 09:02 AM
Welcome to the site.
An actuator motor would more likely be an issue given the work and environment they're subjected to. I'd check at the motor connector for power/cycling distributions. I can provide you with pin out circuit check points if your up to the task.
Old Dec 21, 2023 | 09:05 AM
Hardpivot's Avatar
Yes I would love that!
Old Dec 21, 2023 | 10:33 AM
Sent you a PM
lynnboy021
Jan 7, 2020 10:28 PM
grabbyzz3
Jul 11, 2019 09:06 AM
Chris Ayers
Jan 31, 2013 12:24 PM
greuelc
Mar 16, 2008 08:45 PM
krikhop
Feb 15, 2007 02:44 AM
